Replaces the stock strain relief on the V0 Mini Afterburner toolhead.
- 1x M3x6 BHCS
- 2x M3x30 BHCS
- 2x M3 Nuts
- 1x M3 heat-set insert. (3x5x4)
Instructions
Install the M3 heat-set insert into the top of
Strain_Relief_Body_x1. -
Use the M3x6 BHCS to attach the
Strain_Relief_Body_Top_x1to theStrain_Relief_Body_x1 -
Insert the 2 M3x30 screws from the front of the toolhead, through the motor,
Strain_Relief_Spacer_x2andStrain_Relief_Body_x1finally securing them with M3 nuts on the back of the strain relief. - wires can be routed between the motor and the strain relief, through the recessed area.
