The official release of the Voron Zero 3D printer. You can find the BOM in the configurator located at the Voron Design website.
The current revision is V0.2
Highlights
- Compact and portable
- 120x120x120 build volume
- CoreXY
- Low mass direct drive extruder
- Enclosed chamber
- 24v DC bed
- Klipper firmware
Release History
V0.2 (2023 January)
A majority of the printed parts have changed. The configurator will give you an idea of parts needed if you are upgrading from V0.1.
Toolhead
- New design: Mini Stealth Burner
- Direct Drive Extruder with BMG gears and 20mm thick pancake motor with 10 tooth spur gear
- Improved part cooling ducts (fans are same as V0.1)
- Supports Revo VORON, Dragon, Dragonfly BMO, DropEffect XG, Creality Spider Pro
Drive units
- Motor screw count reduction
- Endstop removed for sensorless homing
Frame
- No changes
Tophat
- All panels have changed
- All side panels are identical
- Extrusion based Tophat
- Hinged design
- Cam locks to secure tophat in place
Panels/Clips
- All Panels are 3mm
- Deck panel changed, new panel is not required
- Split rear panel
X/Y Joints
- Tops became 1mm smaller to accommodate MiniSB
- Endstop block removed for sensorless homing
Bed Assembly
- Printed parts changed, bed position moved 3mm to the rear
Feet/Skirts
- Trident skirt community mod folded into offical release
Front Idlers
- Cam Locks added
V0.1 Inital release (2021 April)
See https://github.com/VoronDesign/Voron-0/releases/tag/V0.1
V0.0 Updates and fixes (2020 Sept)
See https://github.com/VoronDesign/Voron-0/releases/tag/V0.0r1
V0.0 Initial release (2020 April)
