CW1 to Stealthburner PCB Mount.stl v. 1.0.0
1 Screenshot
While building my V2.4127 350mm Printer I wanted to use the SB PCB but I could not find a mount to attach it to the CW-1 extruder. Hence the remix of the two mounts so that you can transition from a SB with CW-1 using the SB PCB to the full SB with CW-2 tool head. you will need to us a 3mm heat insert in the middle mounting hole which is counter sunk in the back of the mount.
