CatPaw is the ideal toolhead for Voron Zero series with Orbiter 2.0 Extruder. I developed this toolhead as I was unhappy with the existing options. The standard Voron Zero 0.2 toolhead does not provide as much cooling as I prefer, and certainly less than the StealthBurner toolhead. My design goals were also minimum loss of print volume and maximum compatibility with toolheads and options for probe and filament sensor.
CATPAW:
- Uses Voron Zero 0.2 toolhead cartridges, so should work with all toolheads for voron Zero 0.2 (fan saver recommended)
- 2x 4010 Blowers, with StealthBurner duct layout for near arctic level part cooling (2x 4010 provides more air than StealthBurner toolhead)
- Almost no loss in print volume. X axis should be full width, loss off a millimeter or so on X if you print with your door closed. (Magnets on my door are strong enough, so the door closes again if the toolhead bumps into it, giving me the full 120x120 mm even when printing ABS
- Option to add the slideswipe Probe. I shortened the probe, but all other parts can be used from https://github.com/SaltyPaws/Voron_0.1and0.2mods/SlideSwipe or original repo (https://github.com/chestwood96/SlideSwipe)
- Option to add under extruder filament Sensor
- Carriages are provided for MGN7 and MGN9 X-axis rails. It is recommended to print the provided X carriage for the appropriate rail. In order to minimize toolhead height, I lowered the screw hole for the rear mounting screw. The CATPAW toolhead will work with the stock Voron Zero 0.2 Carriage, but the screw securing the X-carriage from the rear will not fit.
https://github.com/SaltyPaws/CATPAW_toolhead/raw/main/images/PXL_20240101_224037977.jpg?raw=true
- 2x SHCS (preferred) or BHSC M3x25 bolt
- 3x M3 nut
- 2x NeoPixel
- 1x 3010 hotend fan
- 2x 4010 Blower
- 6x3mm magnets for probe (optional)
- 6mm steel ball for filament sensor (optional)
- Omron D2F-L micro-switch with lever for filament sensor (optional)
- 2x M2x12 or self-tapping screw to secure micro-switch (optional)
Installation Instructions
Assembly should be done in the following order: Probe
- Solder wires to 6x3mm magnets. In order to prevent loss of magnetism, let the magnets cool against another 6x3 magnet.
- Press the magnets into the slots by pushing the toolhead down on a hard object.
- Use a large flat soldering tip at around 230C to push the magnets deeper into the slots, you want the magnets to stick out ~0.5 to 1 mm. Again, let the magnets cool down attached to other magnets to prevent loss of magnetism.
- Ensure wire to magnet path has very low resistance (less than 4 ohm).
- route wires out trough little side window.
- Seal hole with red gasket maker.
NeoPixels
- Create a chain of 2 neopixels. You do not have a lot of space to hide excess cable, so make the wires between the neopixels as short as possible, while still allowing them to slide into the slots.
- Test the neopixels! It will be more rework to remove the hotend fan and part cooling fans later.
Fans
- First install 3010 part cooling fan. Be very careful to only press the edges of the fan, the fan will break when pushing the center of the fan (ask me how I know...)
- Then proceed with installing the blower fans.
- Use a knife to cut the upper right hand side of the blower fan (looking back to front). This is required for routing the majority of the wires. I used superglue to keep the fan together as you will remove a fan closing latch. I accidentally cut int the fanbox, and sealed up the hole with red gasket maker. For details - see pictures below:
https://github.com/SaltyPaws/CATPAW_toolhead/raw/main/images/PXL_20231225_175242278.jpg?raw=true
https://github.com/SaltyPaws/CATPAW_toolhead/raw/main/images/PXL_20231225_175256608.jpg?raw=true
https://github.com/SaltyPaws/CATPAW_toolhead/raw/main/images/PXL_20231225_175325632.jpg?raw=true
Toolhead Cardridge
- Ensure the heater wires are installed pointing towards the right hand fan that has space for wire routing.
- Thermistor, probe and fan wires will fit on the other side (left hand side fan).
- Hold off on installing the zip-ties, these are best installed after the toolhead is installed on the carriage.
Filament Sensor
- Solder wires to filament sensor (2 outer most legs). You may want to shorten the legs somewhat for an easier fit.
- Trim lever, so that lever does not extend past micro-switch body
- Install micro-switch and ball
- Test sensor
Install Toolhead
- Carefully mount toolhead, ensuring that wires are not pinched, and belt is not rubbing on gantry. The bulk of the wires will go in the gap carved out on the right hand side fan, the other side will have sufficient space for probe and fan wires.
Min Probe
- See installation instructions in orignal repo: https://github.com/chestwood96/SlideSwipe
