Power Inlet W Keystone Insert v. 2022.01.18
1 Screenshot
Power-Inlet-w-Keystone-Insert
For Voron 0.1
Description
Adds a keystone slot for the v0.1 Power Inlet. This does not change the way the inlet mounts onto the frame. This was remixed in TinkerCad, using the original v0.1 power inlet, as well as a section of the v2.4 power inlet (the keystone insert portion).
  1. Keystone insert x1
  2. LAN cable x1
  3. Heatset insert x1
Installation
  1. Install heatset insert (per the original assembly instructions)
  2. Cut LAN cable to required length
  3. Crimp it onto the keystone insert
    • I used a toolless keystone insert
  4. Insert keystone insert into the inlet slot
  5. Slide in the prepared power inlet
  6. Mount the power inlet per assembly instructions
