Voron 2.4 SKR 1.3/1.4 Mount for DIN Rail v. 1.0.0
4 Screenshots
G'day, another nice thingy from down under. Got non-standard electronics compartment? Some blocks there that don't allow spec placements? Don't have or don't like self-tapping screws? Or are you just up to better wiring and sturdier construction? Alright, Dropbears to rescue. Here comes a rigid bracket for SKR boards, that uses M3 bolts and nuts, and allows mounting along and across the rail. Each bracket needs 2 of rs25_psu_bracket_clip.stl.
Printing and Plastic
This part is not exposed to any significant heat, so you could probably use even PLA.
  • 8 x M3 hex nuts
  • 8 x M3x12 SHCS screws
Credits
  • that russian guy (aeresov#9959)
  • A Team Dropbear Production
