This is a modified Stealthburner to fit a Mosquito Magnum hotend with a Phaetus UHF Adapter/nozzle. Fan duct to Nozzle Clearance is 1mm. Included are files for 2 mounting options. and the front cover that will fit. The usual side by side mounting, and the probably not very used at all diagonal mounting. Requires 2 heatset inserts. Then you install the screw from the bottom. Let me know if it works for you, or if it needs adjusting.
