DS18B20 Mount
Simple DS18B20 temperature sensor mount based on the z endstop mount.
- 1x DS18B20 / DS18B20-PAR
- 1x 4.7kohm resistor
- 2x M3x10 BHCS
- 2x M3 nuts
- 1x zip tie
Instructions
- Drill hole in rear panel for wires
- Solder/connect sensor, wires, resistor and 4x2 dupont connector
- Position sensor in hole
- Bend sensor leads and secure with zip ties
- Secure mount in place similarly to z endstop mount
- Setup Raspberry PI for 1 wire (see https://www.circuitbasics.com/raspberry-pi-ds18b20-temperature-sensor-tutorial/ for a good tutorial)
- Setup sensor in Klipper
[temperature_sensor chamber] sensor_type: DS18B20 serial_no: sensor_mcu: rpi
Note: you can also position the mount on the inner side of the z axis rails which looks better, but also potentially block access to the z axis for later maintenance.
Images
Example setup using a DS18B20-PAR:
