Remix of RyanDam's Cable Management Duct for Voron Printers v. 1.0.0
6 Screenshots
  • Like 18
This Remix of RyanDam's Cable Management Duct for Voron Printers includes a number of custom ducts which I am using in my Voron 2.4 build.  Thanks to the original author for the excellent design of the ducts, which this remix is based on!
Since these models are designed to work with electrical components, if you use these models, it is at your own risk.
Included here are several customized ducts which may help with cable management in a Voron build.  I am still in the process of building mine, and I chose to use the same electronics layout as the voron spec.  These ducts were designed based on my FYSETC R2.4 kit (which I am building as an R2.4 V2), so some dimensions may be different in other kits.  This was designed with help from the STEP file from the Voron Github.
There are several ducts included, which are designed to go over the DIN rails, and these parts include “BRIDGE” in their names.  These parts will need to be printed with supports.  There is an integrated support in the “HALF_BRIDGE” part, but that could also be printed with supports if needed.  The “HALF_BRIDGE” part also has a thin raft like integrated support which will need to be removed.  The 90 degree full bridge ducts are slightly different between the right hand (RH) and left hand (LH) versions.  The difference is that the RH version (Cable_Management_Duct_Remix_DUCT-FULL-BRIDGE_90DEG_RH_5B.stl) is cut off a bit short to allow the power supply stabilization bracket to pass.
I set my ducts up so that the high voltage AC wires, and the low voltage DC wires, would stay in separate ducts.  To do this, I used two half ducts (one for the AC, and one for DC), on the center duct which crosses the lower DIN rail in the pics, which is nearest the power supply.  I also printed the AC ducts in orange so they would be distinctive as a reminder they contain the high voltage AC wires.
There are also plain and logo versions of the covers.  The covers for the “BRIDGE” parts have print in place hinges, so if you find they are welded together when printed, it will be helpful to calibrate flow and horizontal expansion, as well as adjust the temps for the filament used.  I made some minor improvements to parts since I printed mine (either for length or printability), but I do not think there will be any issues due to the changes.  I printed the ducts for my printer in ABS and PETG, but use your best judgement on the appropriate material to use.  I used VHB tape to secure them, but just note that once placed, they won't likely be going anywhere soon.
Parts are not oriented for printing.
Feedback is welcome, and if there is a problem I will try to fix it as I have time.  I'm still building my printer, so if I run into an issue with this design, I will update it further, however I don't foresee any interference issues currently.  Most likely I will not be able to accommodate requests to customize these further.  The STEP files can be found on Printables (since the file was too large for this site), so remixing will be simpler.  If you print these, or use these, it is at your own risk.
I posted some remix covers for the boxes, which have inset printed labels, as well as some single and double wire guides which I am using to secure my ground wires.  If you find these models useful, please post a like or a comment with some pics of your prints.  You can find some other things I am working on at my blog (https://www.mystoopidstuff.com/blog), thanks for looking!
You can find some additional low profile wire guides here:
https://www.printables.com/model/502345-wire-management-guides
There is a remix of the small box (not included here but shown in the pics), which holds two WAGO 221-415 connectors here:
https://www.printables.com/model/505826-wago-box-for-the-remix-of-ryandams-cable-managemen
The AC caution covers, with inset text and warning symbols for the small box and half bridge duct, can can be found here:
https://www.printables.com/model/505838-ac-caution-covers-for-remix-of-ryandams-cable-mana/files
