Made a drop in mount for anyone still using CW1. Not sure if it'll work with the CW2.
Requires the low profile beacon. The normal version will not work with this mount.
QTY: 2 - Brass heat insert from 2.4 BOM
My Beacon config
[beacon]
serial: [insert your address here]
x_offset: 0 # update with offset from nozzle on your machine
y_offset: 22.5 # update with offset from nozzle on your machine
backlash_comp: [change to whatever yours is]
mesh_main_direction: x
mesh_runs: 2
