Credit
This mod is based on the mod of
- 3DP MAMSIH
- Th3FalleN
- shared in voronuser_mods channel in discord: https://discord.com/channels/460117602945990666/635687829254701107/849006095430844427 or https://discord.com/channels/460117602945990666/635687829254701107/849035515802288158
Thank you for your awesome work!
Print settings
As stated in the Voron documentation:
- ABS
- 0.2mm layer hight
- 0.4mm extrusion width
- 40% infill
- wall count 4
- top/bottom layers 5
- no supports
Bom
- 2x heat insert m3
- 2mm wide zip-tie
Improvement
Added a cable strain-relief
Description
I really liked the adxl mount posted in the voronuser_mods channel by 3DP MAMSIH. Thanks to Th3FalleN it was modified to have heat-set inserts. I added the possibility to fix the cable to the mount, so it does not need to hang directly from the adxl pin headers.
