Showing results for tags '3d mamsih'.
  • Other FDM Printers / CNC
    • Bambu Labs
    • CNC
Found 1 result
  1. Version 2021.11.20
    159 downloads
    Credit This mod is based on the mod of 3DP MAMSIH Th3FalleN shared in voronuser_mods channel in discord: https://discord.com/channels/460117602945990666/635687829254701107/849006095430844427 or https://discord.com/channels/460117602945990666/635687829254701107/849035515802288158 Thank you for your awesome work! Print settings As stated in the Voron documentation: ABS 0.2mm layer hight 0.4mm extrusion width 40% infill wall count 4 top/bottom layers 5 no supports Bom 2x heat insert m3 2mm wide zip-tie Improvement Added a cable strain-relief Description I really liked the adxl mount posted in the voronuser_mods channel by 3DP MAMSIH. Thanks to Th3FalleN it was modified to have heat-set inserts. I added the possibility to fix the cable to the mount, so it does not need to hang directly from the adxl pin headers.
