Voron 2.4 Cable Tie Mount for DIN Rail v. 1.0.0
2 Screenshots
G'day, another nice thingy from down under: a simple bracket that allows fixing your cables with standard 3.5mm plastic cable ties in various positions. 4 ties per bracket, 2x2 criss-cross, so you can make bends or straights. The bracket needs 1 of rs25_psu_bracket_clip.stl.
Printing and Plastic
This part is not exposed to any significant heat, so you could probably use even PLA.
  • 2 x M3 hex nuts
  • 2 x M3x12 SHCS screws
  • standard 3.5mm cable ties
Credits
  • that russian guy (aeresov#9959)
  • A Team Dropbear Production
