C17 EXT v. 2022.07.24
7 Screenshots
C17 -EXT, External HEPA Carbon filter
The C17-EXT filter replaces the standard filter of the Voron 2.4 and to add one on the Switchwire . It has a 120mm fan and can use the C17-EXT-Cartridge filter (HEPA 13 and Carbon) or commercial HEPA Carbon filters.
This is a first publication, although all parts has been tested, there may be errors do not hesitate to contact me.
2 configurations
With adapter for standard back panel Voron
With specific back panel
For the Switchwire model only configuration 2 is possible.
2 options to replace the grid
Extractor for 125mm tube Extractor for 100mm tube
Assembly Manual
Manual
BOMs
The list of parts is described in the manual according to the chosen configuration.
Fan
For the 120mm fan, follow the recommendations in the documentation. 3 models:
  • Efficient but noisy, the best choice (4000 rpm) : Aquatuning Alphacool 24810 ES (tested)
  • Less powerful but quieter (3000 rpm) : Noctua NF-F12 iPPC 3000 PWM (tested, acceptable for commercial cartridges)
  • Less powerful but quieter (3000 rpm) : Sunon MEC0251V1-000U-A99 (Not tested)
If you find other models at 4000 rpm, please send me the references.
Filter cartridge
Two possibilities :
Credits
The C17-EXT Activated Carbon Filter was modelled in Fusion 360.
Contributing
A complaint is a gift. Please, help me to improve the C17-EXT filter !
License
Distributed under GNU General Public License version 3.0 (GPLv3)
Contact
Discord: OboMaker3D#0669 - ()
Acknowledgements
The Voron Dev Team
