6
This is a simple nut adapter to keep hex nuts in place inside the 15mm extrusion if you're using mgn9 linear rails. This complements the MGN9 X-axis mod for the V0.1. The hole spacing is 20mm center-to-center between each screw hole and 5mm edge to center on either end.
