Trident Inlet Skirt For Schurter DD11.0124
This is a modified inlet skirt for VORON Trident to install a Schurter DD11.0124 or similar power inlet.
Print using standard VORON print settings. You'll need the same 2 heatset inserts and 2 FHCS screws as the stock filtered inlet to mount this.
