Corner panel clip with an internal cable path, so you can route the cables around the panel and corner.
I use them to mount 6mm floatglas as top panel with 3mm foam tape
corner_panel_clip_top_4mm.stl is 4mm and corner_panel_clip_bottom_3_5mm.stl is 3.5mm height,
so at the end there is 7.5mm space for the panel and foamtape.
Needs 2x M3x12 screews to mount per clip.
