6
I've made a mount for the Beacon3D probe for a CW2 Switchwire
I used the normal version beacon probe
Mount has been tested and works great, here is a youtube short of it in action
*** I've added a second mount as that moved the probe 2mm further away I wasn't happy with the original mount because as soon as the carriage got a bit melted the probe would start touching the heat block. I also believe because the probe is so close to the heater it causes the mount the deform.
