9
Top Corner Cable Cover with Drop Down Holes (LED Wires)
Covers cables that are running around the top corners of 2.4R2 extrusions behind the Z idlers with drop down holes around the vertical extrusions and inline holes with cutouts to keep the wire management as clean as possible.
Holes are big enough to allow 2 pin microfit connectors pass through. Works perfectly with LDO LED PCB breakout board.
CAUTION Check your max Z travel as there will be some loss.
- Print 1 cover per LED strip
- Default voron settings
- No supports needed
| Size | Qty |
| M3x8 | 2 |
| M3 T-Nut | 2 |
- QTY per cover
