Corner Cable Cover With Drop Down Holes v. 2022.08.29
3 Screenshots
  • Like 7
Top Corner Cable Cover with Drop Down Holes (LED Wires)
Covers cables that are running around the top corners of 2.4R2 extrusions behind the Z idlers with drop down holes around the vertical extrusions and inline holes with cutouts to keep the wire management as clean as possible.
Holes are big enough to allow 2 pin microfit connectors pass through. Works perfectly with LDO LED PCB breakout board.
CAUTION Check your max Z travel as there will be some loss.
  • Print 1 cover per LED strip
  • Default voron settings
  • No supports needed
Size Qty
M3x8 2
M3 T-Nut 2
  • QTY per cover
