14
Hidden cable routing z belt cover mod
Credit
Mod based on the design of the Voron crew. Thank you for your awesome work!
Print settings
As stated in the Voron documentation:
- ABS
- 0.2mm layer hight
- 0.4mm extrusion width
- 40% infill
- wall count 4
- top/bottom layers 5
- no supports
Bom
Only the printed file.
Improvement
Added the possibility to route cables on the bottom of the cover.
Description
I liked the design of the old Voron 2.2 covers more than the current design so I based my mod on them.
This mod allows to route cables that are hidden in the extrusions to the bottom compartment. To achieve that the inner part of the z belt cover is a bit thicker and a path is cut out on the bottom where cables can be routed. The overall dimensions are the same as the stock 2.2 covers.
Note: Be careful to restrict the cable in the bottom compartment so it does not rub on your z-belts.
Pictures
Top:
