FYSETC SPIDER DIN Bracket
Minimalist DIN bracket for the FYSETC SPIDER, based on the simple design of the core SKR bracket. It uses a standard build pcb_din_clip_x3.stl, and provides integrated horizontal and vertical mount options so you can choose on the fly.
Use the standard Voron 2.4 recommended print settings.
- 4 x M3x8 SHCS screws
- 1 x
pcb_din_clip_x3.stl - 2 x whatever hardware you use to mount your other
pcb_din_clip_x3.stlclips (I use M2x6 screws, but the BOM self-tapping screws work as well).
Images
