I wanted to use Demosth's Stiffer DinMount for my PSU, but as I had ran out of self tapping screws and didn't want to wait for new ones to be delivered I modded his design slightly to accept M3 screws and nuts. Because the spacing between the screw holes would not fit the PSU's mounting holes center-to-center distance without interfering with the spring design, I added a very simple base plate which bolts onto the PSU using M4x6 screws.
Assemble the DIN bracket onto the base plate first, then the base plate onto the PSU.
These mounts are for PSUs with mounting holes 50mm apart center-to-center.
The tolerances of the holes are tight, so your printer has to print with dimensional accuracy or the screws won't fit.
If too tight for your printer, try using Hole Horizontal Expansion in your slicer.
Photo sample printed with 0.3mm layer height, 0.5mm width, 7% infill, complete set of 4 in about 37mins.
No supports needed.
Hardware:
- M3x10 SHCS x 4
- M3 nut x 4
- M4x6 BHCS x 4
