V2.4 Dual Screw Front Idler Mod r3 v. 1.1.0
3 Screenshots
  • Like 12
  • Voron FTW! 2
After a couple of chewed ab belts and finding that the r1 front idlers were the culprit i looked into r2 idlers but didn't like the screw going through the join/split and personally i think that is a bad design feature so i then looked at other idler mods but didn't like the look of those either because to me i didn't think they kept the look of the voron, i have nothing against those designs but wanted to keep the original look of the parts but with better functional integrity so i modified r1 idlers to 2 screws keeping the part join/seam in the middle facilitating the screws going through either side of solid media allowing for an even pull on the idler pulley and even slight alignment adjustments if needed, i have been running this mod now for over 80hrs printing and is working fantastically....
Print as per Voron Spec and only requires 2 extra heat sets and 2 extra m3 screws with washers...
RepRapster3D's Other Downloads
