Voron 2.4R2 build - Formbot - recommended upgrades/adjustments/mods build - full guide.
Buurman
Getting closer to the real end... (if thats possible.. really.. since I already have 3 more mods on mind..
So hung the front windows yesterday with a new hinges mod (for me)
And I gave them a 5 star rating, since.. well, this now belongs to my top 5 mods, possibly on spot 3. (not that it matters)
Love the backdrop panel on my printer, will take a better picture later, but I took a good picture before it went in my printer here:
Now the printer is printing parts for two new Vorons 2.4 so other mods will be a little slower, yet the Ellis bed fans will go in tomorrow I hope, I noticed chamber heating is much slower without fans...
  On 1/1/2023 at 1:57 PM, Buurman said:
Anyone experience with the BTT 5" making these colors as screensaver?
Expand
No, can't say I have.
The only help I can offer is the following thread I came across. Maybe something in there
https://github.com/bigtreetech/OctoBTT/issues/12
  On 1/1/2023 at 9:58 PM, Stadi said:
Are you sure it's coming from the BTT and not somehow from the Klipperscreen or the Pi?
Expand
Sure, most likely... but then... did a default installation, need to find the setting, its exactly this:
And this:
Trying turning off DPMS, I know in 5 minutes, but didnt think it helps, since I tried it before I think... what IS DPMS anyhow...
For less serious topics… 😂
have an extrusion issue I guess.. had to cancel a 10 hour print half way, since I noticed the missing layers…
first I thought temperature, but when removing them I see they were there all along…
First thing I test is this extruder “distancing” screw, this very small screw on-site your cw2 for distancing your gears. I think I may have been a bit too enthousiastic on having them run loose, I think when filament get hotter in the chamber, it’s easier to start slipping.
at least that’s my theory… running test print now.
I turned it tighter so the gears come closer, more pressure on the filament gears so more teathing.
hard too see on above photos but the sides are actually smooth, yet missing full parts/layers. the light makes it look like its bumpy all over, yet its not.
The infill is also messy... changing to grid again, forgot to change it back.
For the Revo, any advise on temperature, are printing temperatures the same as with a heatblock (like dragon) or should I lower/higher temperatures?
I have the feeling they dont need to be changed, but just checking with others who have Revo experiences.
I am also suspecting the TAP a little, that the magnets somehow are not strong enough and the nozzle gets bumped up to easy, instead of squashing the filament, this way bumps get higher and higher, specially during infill, you will always cross dried/harder lines..
Ah well... troubleshooting....
Well if I needed more convincing to leave my 2.4 in the attic, you've scared convinced me.
Expand
Stefan's (CNCKitchen) review on the Revo was interesting, beyond pointing out that the heat-up time is way inaccurate (not an issue as I'm sure you heat soak everything for ages) he did indicate the final "stable" temperate is 3C below the reported temperature. Dunno if that would make much of a difference.
However, I think you're perhaps onto something with the TAP perhaps introducing nozzle variability. Is there any way of monitoring the switch in the TAP to see if it's falsely triggered or is it not moving enough?
I think the sensor is disabled during printing, but maybe its just my case and normally the magnets should hold it in place very well. I still wonder why they didnt use magnet on magnet connection, I think there is space enough.
Maybe that was too strong? but maybe my iron screws are not good enough (bad enough) to hold it very strong, it doenst feel like I really need to push it, to release it, but maybe that not the purpose.
Experiment..
I did reprint some parts and they look perfect now, so 3 things can be the cause...
The adjustment screw (this test and so.. its fixed)
The temperature, long print on 60 degrees chamber, may cause overheating of the extruder motor
ABS+ since my test now was in PLA, so i didnt have to heat up everything so long every time I run a test..
I really dont like ABS anyhow, why I bought 2 spindles of it, i dont know, it stinks...  even though I think its more flex than ASA.
But for me, I keep it all ASA from now on...
I do feel like I may go back to a Klicky setup with fixed SB, I will give it another try with a new TAP build (and stronger magnets/screws) but I feel I hear it running over infill and normally I dont have that, and I hate this noise.. since its often the sound before a break of the bed..20230102_122451967_iOS.thumb.jpg.cb848ad5f861a9891dded71ee3f10edd.jpg
Expand
Wouldn't think it was that, 60C should be in the operational range for a stepper, anytime I've seen heat related issues with steppers it's been the controller rather than the motor (unless it was a really cheap stepper? 😛 ) besides those lines and wiggles look too "consistent" to be a stepper randomly skipping steps and extruding oddly (but that might just be the flattering photography). Unless you've got CANBUS and the motor driver is too toasty being in the chamber as well.....
What voltage are you running the CW2 motor? I started at 0.4A on mine and ran into underextrusion skipping, I ultimately ended up at 0.6A and it's not been an issue since.
I've only used Revo in the Trident, and switch to one on my Prusa Mini. I haven't run into any issue with heat (except for the couple of failed heaters). They heat up quickly and are rock solid once at temp. I ran the full Ellis tune (Github version) and my temps are within the manufacturers' stated ranges, so I don't see anything odd with the temps. I also didn't really change them from stock settings on the Mini. IMHO the claims of temp issues are overblown on Revo.
Expand
Im running it 0.55 and its a Moons by Mellow (high heat resistant) so I am not thinking of heat..
And slipping by power also not, but thanks, because it could have been that, I just copy/past my configs from previous builds that I "optimized".
  On 1/2/2023 at 2:43 PM, Wick said:
maybe an extrusion multiplier issue
Expand
Ah yes, this could be, I havent tuned much yet, so that part I still need to do. It does look worse on photo than reality, but yes, I seen it too. I do print 45 degrees by default yes.
Changed some setting and compared to ELLIS his profile to just get some things updated/tested..
I think its a bit too fast on the travel for my taste, feel like the printer wants to walk away, but beside that..
better result...
Expand
My standard for ABS and ABS+ (eSun) is bed 100, hotend 240.
Expand
Should not be the 60C as I run my bed at 100 - 110C, Chamber gets up to 47.9C. Extrusion would be my guess
