5
| Part NO. | Qty | LCSC |
| Conn_01x03 | 2 | C131339 |
| WS2812-2020 | 12 | C965555 |
- Order the pcb at e.g. pcbway or jlcpcb (you need two for one printer)
- Order the parts at e.g. lcsc
- Print the new skirts (You WILL need supports)
- Print the new logo inserts (You WILL need supports)
- in the meantime, assemble the pcb
- Push in the new logo inserts in your skirts
- Push the PCB into the logo insert, no additional fastening required
- Wire up the pcbs to your controller
- Add them as normal neopixels to your config
[neopixel my_skirts] pin: YOUR_NEOPIXEL_PIN chain_count: 24 initial_RED: 1.0
- https://github.com/Gi7mo/TridentSkirtLights/raw/main/Images/Assembly.png
- https://github.com/Gi7mo/TridentSkirtLights/raw/main/Images/trident-skirt-lights.gif
Notes
- This project does not come with any warranty, if you choose to build/use one, you are doing this at your own risk!
