6
Bed fan mount for the V0. Uses an 80x80x25mm fan, I used this GDSTime one. It makes the enclosure heat up faster, and the bed cool down faster after prints.
Fan definition:
[fan_generic enclosure_fan]
pin: PB8
max_power: 1.0
shutdown_speed: 0
cycle_time: 0.01
hardware_pwm: False
kick_start_time: 0.1
off_below: 0.2
Klipper macro for preheating the enclosure:
[gcode_macro PREHEAT]
gcode:
M140 S110 ; Preheat bed
M104 S160 ; Preheat hotend
M106 S255 ; Part fan at max
{% if 'xyz' not in printer.toolhead.homed_axes %}
G28 ; Home axes
{% endif %}
G0 X60 Y60 Z110 F5000 ; Move bed down and AB to middle
M190 S110 ; Wait for bed to hit 110
SET_FAN_SPEED FAN=enclosure_fan SPEED=1
If you use this, make sure to also turn off the enclosure fan in the PRINT_START:
SET_FAN_SPEED FAN=enclosure_fan SPEED=0
Klipper macro for cooling down the bed after the print ends:
[gcode_macro COOLDOWN]
gcode:
{% if printer.toolhead.position.z < 110 %}
G0 Z110 F3600
{% endif %}
TURN_OFF_HEATERS
M106 S255 ; Part fan to max
[gcode_macro PRINT_END_COOLDOWN]
gcode:
M400 ; wait for buffer to clear
G92 E0 ; zero the extruder
G1 E-4.0 F3600 ; retract filament
COOLDOWN
{% set max_y = printer.configfile.config["stepper_y"]["position_max"]|float %}
G0 X60 Y{max_y} F3600
M190 S50 ; Wait for bed to cool down (note: will heat to 50)
M190 ; Turn off bed
; Turn off fans
M107
