For use with Eddie's LED_Bar_Clip, this is a 50mm corner piece that hides wire management and fills out the corners. Comes with eyelet for a zip-tie and two M3 loose-fit thru holes for screwing to the extrusion (could modify for clips but would require support to print)
Pieces are 50mm square, on my 250x250 I have 16 of Eddie's clips and one of these on each side. You may need to adjust the size depending on your build, but the FreeCAD file provided should still hold up if you want to adjust the dimensions (I tried reducing to 45mm square and it turned out fine)
Hope this helps with making pretty lights!
~happylittlePCBs
