Voron V2.4 Z Chain Guide with Integrated Thermistor Mount
When looking for a clean way to mount a chamber temperature sensor, the Z chain guide seemed like a perfect opportunity. It should fit any thermistor with a 3mm barrel.
Installation
- Route your wire through the Z chain to the rear X extrusion
- Secure the wire inside that extrusion
- Insert the thermistor into the mount
- Attach the mount to the extrusion, positioned to hold the Z chain vertical*
**NOTE: Ensure you have enough links in your Z chain to clear the guide when at max Z.*
