Milo V1.5 CNC Bench Mill - Water Cooled - Casa Enclosure
Drilled some counterbore holes with the drill press in the fixture plate. Fastened with M5 x 10. Next is the shim for flatness, and check the tram again. All shimming done, they're was a big bow in the middle of the plate 😲 . Tram next!
The reason for additional securement points is that the end mills apply an upward force when cutting.
Found a local supplier (100KM away) for aluminum stock. They sell off cuts picked up this lot today for $100.00 CND, all 7050 aluminum except for one piece of 2024.
