4-inch Touchscreen for OctoDash - Voron 2.4
OctoDash
OctoDash is a very cool dashboard / touchscreen UI for OctoPrint that you can download and install on your Raspberry Pi. It is recommended to configure your Pi with auto-login to desktop and auto-launch the OctoDash app at startup.
Touchscreen and Cables
Octodash will work with almost any display attached to the Pi but I found this really nice 4-inch IPS touchscreen on AliExpress that is perfectly suited - so I built a mount to integrate it into the V2.4 skirt as a drop-in replacement for the stock front panel. As such it should work on any size V2.4 (250/300/350) with the stock left- and right- front skirt pieces.
When buying this screen I recommend you choose the
