This is designed to fit the Waveshare 4.3" USB-touch version of their HDMI TFT touch screen.
It mounts to the underside of the rail in the same manner as the skirts, using t slot nuts and M3x8mm socket head cap screws. The screen attaches to the housing using the four screws that come with the touchsceen.
This will only fit if you have the 180 degree HDMI and USB adapters that come with the Waveshare display. See attached picture.
This is designed to fit the 300mm and 350mm Voron models. You will need to use the front skirts for the next size smaller Voron. For example, if you put this housing on a 300mm Voron, you will need the front skirts for the 250mm version. The 350mm Voron will need the skirts from the 300mm.
If your screen doesn't come with the screws, I believe they are M2.5x6mm, but im not certain.
I've included the .stp file, in case someone needs to modify a version to fit something else.
No supports needed.
