Voron housing/case for BTT Mini12864 display v. 1.0.0
4 Screenshots
This requires front left and right skirts that are 1 size smaller than your printer.  For example, if you have a 300mm Voron, you need the front skirts from the 250mm printer.
It attaches to your printer the same way the skirts do, using two M3x8mm screws and 2 T slot nuts.
The bezel will require four standard Voron size M3x4mm heat set inserts, and the bezel, and screen are held in using 4 m3x10mm socket head cap screws.
The bezel accent insert is attached to the bezel using super glue.
