This mod comes in two parts, a fixed mounting plate which anchors to the v0 frame with m3x6 screws and a detachable front plate which holds the acrylic panel.
Front Panel
- 6 - M3x6 screws
- 6 - M3 nuts
- 22 - 6x3mm magnets
- Printed parts
Side Panel (each)
- 6 - M3x6 screws
- 6 - M3 nuts
- 28 - 6x3mm magnets
Assembly instructions:
Front panel
- Remove front two feet from V0
- Preload 3 m3 nuts to each front extrusion
- Attach mounting plate to front of V0 with M3x6 screws
- Insert magnets into the 11 holes on the mounting plate
- Using VHB tape, affix clear acrlyic to the panel mount part
- Insert magnets into the 11 holes on the panel mount, be sure to match polarity properly!
- Re-attach front two feet
Side panels
- Remove side two feet from V0
- Attach mounting plate to V0 with M3x6 screws
- Insert magnets into the 14 holes on the mounting plate
- Insert magnets into the 14 holes on the panel mount, be sure to match polarity properly!
- Re-attach two feet
