README
Overview
Inspired by the print in place tension meter Prusa released recently, I drew up this one from scratch.
It's not intended to give you an absolute result but I found it accurate enough to measure the same tension independent off the orientation you mount it with. Therefore it should be accurate enough to set multiple belts to the same tension (e.g. V2 z-belts).
Print instructions:
Only tested with KVP ABS.
Always print it with 100% infill
Application:
The meter has three
