Simple LED mounts to run along the top of the V0 frame.
12mm mounts are sized for a 12mm wide LED strip. This was used for a small strip of RGBW LEDs. 10mm mounts are sized for neo pixels strands. One has a channel so that the data pin can be routed to the other side.
