Voron Afterburner Toolhead PCB Cover
This cover is made for the tool head PCB from HARTK. To mount the cover, please use a 22 mm M3 screw. The sleeve is used as spacer between PCB and cover.
It should be also possible to use the cover without the PCB. For that you have to design and print a custom sized sleeve part.
New version with Air Vents
This is an updated version to the cover with air vents for better air flow to the thermistor on the PCB.
