V2.4 Front and Side skirt with switch mod
Follow the manual for instructions on installation and wiring.
NOTE: I am by no means a CAD professional. I have only tested the 300mm mods. Feel free to contact me on the Voron discord (tayto-chip) if you would like the step files.
All screw and heat-set insert holes are unchanged.
Switch used is from the V2.4 sourcing guide: ZF Rocker Switch
Images
