Showing results for tags 'Dr-Info'.
Version 2022.11.18
347 downloads
V2.4 Rear Skirt Mod for Z-Drive Motor Tensioner Mod Credit for the Mod goes to Edward Yeeks for the orginal design and Skohls for updating the mod for the R2 changes. https://github.com/VoronDesign/VoronUsers/tree/master/orphaned_mods/printer_mods/edwardyeeks/V2.4_z_drive_motor_tensioner_mod This mod enables the you to utilize the rear skirts, power and keystone, in your V2.4R2 while still being able to use the Motor Tensioner Mod. NOTE: heat set insert holes are in a new location so you will have to reposition your bottom panel clips and hinges. Printing Default voron settings No supports needed BOM Same hardware for mounting skirts for Voron V2.4r2. -
Version 2022.08.29
228 downloads
Top Corner Cable Cover with Drop Down Holes (LED Wires) Covers cables that are running around the top corners of 2.4R2 extrusions behind the Z idlers with drop down holes around the vertical extrusions and inline holes with cutouts to keep the wire management as clean as possible. Holes are big enough to allow 2 pin microfit connectors pass through. Works perfectly with LDO LED PCB breakout board. CAUTION Check your max Z travel as there will be some loss. Printing Print 1 cover per LED strip Default voron settings No supports needed BOM Size Qty M3x8 2 M3 T-Nut 2 QTY per cover
