How to Use CAN Toolhead Boards Connected Directly to Octopus / Octopus Pro on CanBoot
Go to solution Solved by mvdveer,
1 hour ago, michaelmacintyre said:
Can I just verify that it's a Canbus board your trying to setup?
If it's jst a normal wired toolhead board it's different to setup.
I have attached a picture of a EBB36 can board with the usb jumper next to the usb port.
That's the one it's a 36 1.1
EBB/BIGTREETECH EBB36 CAN V1.1 User Manual.pdf at master · bigtreetech/EBB (github.com)
page 8 on that manual shows you that you need to connect the jumper onto the vusb pins i think they call it if you are not powering it via 24v. you shouldn't power this board via 24v until it's flashed ready to go as it turns on the heater for the duration it's in flash mode. there should be two buttons on the back to put it into flash mode which is in the manual. once your in dfu mode (flash mode) running the ls /dev/serial command should show the board.
not spent any time since i fitted the ebb42 but i have found an issue
I have transferred all the relevant settings to the new ebb42.cfg but my esteps are now miles out. previous rotation distance was 21.9759 new calculated is 3.9117102. i have not applied yet as im thinking this is not right and something else is wrong any ideas?
doesnt matter im an idiot didnt transfer the gear ratio
Edited by JGD13
trying to the can0 up and running but it is not any answers
pi@voron:~ $ ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether e4:5f:01:91:1e:d4  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.50.234  netmask 255.255.255.0  broadcast 192.168.50.255
        inet6 fe80::da67:eefa:3ed3:f77c  prefixlen 64  scopeid 0x20<link>
        ether e4:5f:01:91:1e:d5  txqueuelen 1000  (Ethernet)
        RX packets 352  bytes 62545 (61.0 KiB)
        TX packets 242  bytes 47219 (46.1 KiB)
pi@voron:~ $ ~/klippy-env/bin/python ~/klipper/scripts/canbus_query.py can0
Traceback (most recent call last):
  File "/home/pi/klippy-env/lib/python3.7/site-packages/can/interfaces/socketcan/socketcan.py", line 679, in _send_once
    sent = self.socket.send(data)
OSError: [Errno 100] Network is down
During handling of the above exception, another exception occurred:
  File "/home/pi/klipper/scripts/canbus_query.py", line 64, in <module>
    main()
  File "/home/pi/klipper/scripts/canbus_query.py", line 61, in main
    query_unassigned(canbus_iface)
  File "/home/pi/klipper/scripts/canbus_query.py", line 25, in query_unassigned
    bus.send(msg)
  File "/home/pi/klippy-env/lib/python3.7/site-packages/can/interfaces/socketcan/socketcan.py", line 658, in send
    sent = self._send_once(data, msg.channel)
  File "/home/pi/klippy-env/lib/python3.7/site-packages/can/interfaces/socketcan/socketcan.py", line 681, in _send_once
    raise can.CanError("Failed to transmit: %s" % exc)
can.CanError: Failed to transmit: [Errno 100] Network is down
pi@voron:~ $
    main()
    bus.send(msg)
pi@voron:~ $
just seen your message. since it says network is down lets look at that.
Can you remind me please what can controller you are using?
are you using the canbus built into an octopus or something like a U2C?
Have you performed something like this......
auto can0
iface can0 can static
 bitrate 500000
 up ifconfig $IFACE txqueuelen 256
 pre-up ip link set can0 type can bitrate 500000
 pre-up ip link set can0 txqueuelen 256
auto can0
 bitrate 500000
Ok I figured it out but I go through everything and mainsail won't allow me to upload my config file. So think I have a bad mainsail
2 minutes ago, michaelmacintyre said:
yeah that is strange. have you tried uploading the files using winscp? are the dashboard buttons all there? are you able to get to the dashboard without a config loaded?
So that's my dashboard and the other us my winscp where my config is.
your config has an include in it looking for the ebbcanbus file but the file is not in your klipper_config folder.
I doubt that is why your buttons don't show but it's just what jumped out at me.
you might be right though about needing to do install mainsail but i would start by either removing the ebb canbus include first or put the file in the config folder
1 hour ago, Pradit said:
Hi just would like to know anything wrong with this message?
And the /tmp/printer, baudrate 115200 is that the rate CANBUS use which I set to 500k?
The baudrate is not what's used for canbus it's the bitrate in the canbus network and when your flashing your canbus board. Those need to match so if you set the network to 500Kb then you set the same when flashing the board. the bitrate is usually connecting via serial(usb) to your mcu.
Are you using serial to connect to your mcu or are you using canbus bridge?
I'm using canboot. is it serial or canbus bridge? (EBB36 + Octopus pro)
