Voron Tap Released!
Demosth
4 hours ago, claudermilk said:
Well, I tried Tapping this weekend and it didn't go well. No smoke--I put the suggested resistor in so that is good so far. The issue I am having is the LED on the V2.1 PCB lights up, and won't turn off. For some reason the optical sensor will not trigger at all. I currently have the board hanging loose and even when I cram some black cardboard in the sensor slot it does not react. I'm not sure if I have a bum board or if wiring is messed up or what. I'm reusing the stock spec probe wiring in my harness (24V/S/GND) which still has the BAT85 soldered in line. Still on the same pins on the controller--I haven't gone in there to mess with anything.
Plan B is to swap out to UnTap later today if I have time. I also found one of the recommended wired optical sensors in stock at Digikey, so I ordered a couple of those to try for plan C.
Just an FYI - i had similar issue with my v2.1 vendor bought sensor and it cam down to bad soldering job. I re-soldered about 3 suspect looking joints and it started working as expected. I have tap working even though I don't have a build plate yet 😕
While I like so much about it...  seriously considering to go back to Klicky sometimes.
I miss the pure consistancy, the TAP is just OFF sometimes, and I think just for filament ooze, or something.
Klicky always works if build well (mostly the magnets montage) ...
TAP can still use some work I feel... or just good ideas that I am not smart enough for :- p
The 5V boards appear to have almost no components aside from the sensor and plug. So, you will want the inline resisto
I have the 5V board - NO resistor needed - this has it on the PCB already. Mine has been working without a hitch on the 2.4 ever since install.
See manual p15:
See manual p15:
Now you JINXed it... you will see 😛 hahaha!
38 minutes ago, Wick said:
it's a 2.2 Ohm and not 2.2kOhm to avoid that high inrush voltage that toasts the regulator on the 5-24V Board.. see here
That's very interesting. The 2.2K Ohm value I got was from the link @claudermilk posted. If he's using a 2.2K Ohm resistor that might be the reason why his Sensor PCB isn't being recognised.
Can confirm it is a 2.2ohm resistor if you have a faulty 24V board, soldered inline. Does not apply to the 5V boards
the 2.2 Ohm inline is only neccessary if you use 24V, not if you use it on 5V. theres also a modification to transfer the V2.1 to a 5V only sensor (maybe you can repair a toasted sensor with this as you remove the toasted U2):
Edited by Wick
I think I read the same thing you did. TAP Issues
Also a good idea to heed this warning. Edit... Best to get the grey metal oxide film resistors.
"Use a 2.2Ω wire-wound or metal oxide resistor, 1/2W rating should be good. It is probably important to use a wire-wound, metal oxide, or carbon composition resistor rather than the more common thin-film resistors because they have better power pulse characteristics. The resistor will briefly see a high-wattage pulse at powerup (perhaps 1-200W over 10 µs), and this can quickly break down thin-film resistors."
Edited by Penatr8tor
Oh, that! That's for the Moonraker update. I warned him it would break like that. 😄 I didn't read your post well enough--I was fixated on my Tap tribulations.
There's a pin in the Discord Tap channel pointing to the Github issue #42. They are saying that voltage inrush--especially when hot-plugging (why would you hot-plug your sensor?)--is exceeding the part specs and is blowing it up. The resistor is to reduce that voltage to within specs and prevents the release of smoke. There's a lot of good info in the temporary fix description. Most goes over my head, but I understand enough of the concept to see where they are coming from.
