VzBot 330
1 minute ago, TitusADuxass said:
I should really stop trying to multitask
What's the fun in that?
go back to bed with a beer.
Now that's not a bad idea. But multitask with a beer 🙂
17 hours ago, mvdveer said:
It uses a RP2040 chip thus pin names are "GPIO" nominated not "P"
 Example: sht36:gpio21 instead of the v2 sht36:PA2
Good to know, the moment I read that it clicked, and I had an Ah Ha! moment.
An interesting problem.
When I buzz stepper Y it does this.
All other steppers do the normal smooth back and forth motion.
So far I've:
Checked the 5160 driver power supplies
Swapped out the 5160 (both parts and ribbon cable).
Swapped the mainboard
Swapped the motor
and still have yet to clear the problem.
I connected up a spare stepper motor (TronXY 23) and that does someting different. It only moves in one direction.
The .cfg has not been changed from a known working config.
The only thing that I haven't changed is the Pi, but I can't see how that can be the problem.
Any suggestions good people?
An interesting problem indeed.
What did the other motor do? I assume you just had a motor on the table, connected to the controller. It would be interesting to connect test motors to both the Y and Y1 drivers and attach a tape flag to the shafts and see if they both move in sync.
I'm thinking maybe they are not sync'd and thus the noise.
...and I just thought of something... do you think maybe the grub screw loosened? The Super Power LDO motors do not have a flat machined on the shaft so, you may have had a pully slip on ya.
Might be worth checking.
Yes I had the other motor on the table. The other motor incremented in one direction, i.e. it went forward by 1 mm but did not travel back 1 mm. Buzzing Y1 gives a normal result - forward and back by 1mm with the appropriate sound.
I too thought about sync problems, it sounds very much like the motor is fighting against another motor. So I loosened off the grub screws on Y to allow it to rotate without driving the belts. It still does the same noisy ´movement.
Did you try a new good stepper motor cable when you tested?
I assume you did but at this point it looks like you've swapped out everything except the printer frame.
At this point you might want to try reflashing your controller. Crazy but hey... try everything right?
I made up a new cable.
I think a reflash is required as it is now saying that beacon is not a valid config section!
There's only 3 things to do, either:
1. Reflash
2. Swap out the BTT Pi2 for a real Pi4
3. Put my old Manta M8P/CB1 in!
Swapping out the Pi didn't change anything.
Now klipper won't start because it doesn't like the beacon section in the printer.cfg.
What I'm going to do now is revert back to the original setup (without beacon).
If that then still gives me the same problem with stepper Y I'll fit my old M8P/CB1.
I'm still fettling with this.
I've swapped out the board for a Super 8 v1.3, and promptly let put the magic smoke out!
So, as a last resort I've put an old Manta M8P/CB1/ in along with the UTOC. So far so good, I'm just trying to nail the can setup. I've got the UUID of the SHT36, but now the /dev/serial directory has disappeared.
The next step is try configuring the M8P in CAN Bridge mode - the problem is - the sun's shining,  it's +14c and it's Friday afternoon....
Yup, I just bought a new ride a week ago and I'm itching to go on a nice long drive...
It's 23c and sunny here and she is calling me.
2 hours ago, PFarm said:
Awesome ride! The road calling go for it!
Thanks, I kinda cheated and drove to lunch and back. 😁
Tomorrow though... I'm gonna hit the road for a couple hours.
1 hour ago, claudermilk said:
Zoom Zoom! Mazdas are great. My sister got a CX-30 about a year ago and loves it. The 20-year old 3 got passed to my niece and is still running strong.
Yup, I'm kind of a Mazda fan. I traded my 2019, fwd, non-turbo CX-5 for a 2023 CX-50 Premium Plus AWD Turbo with 20K miles. The difference was ~13K so not too bad of a deal.
I originally selected the CX-5 because it was a cost-effective little SUV to drag a motorcycle behind and Mazda was the only one offering a 6-speed dual clutch transmission the only thing that disappointed me was that the engine felt a bit overworked towing a trailer.
I'm really liking the CX-50 so far. 0-60 in 6.6 seconds isn't bad and the towing capacity goes from 2000 lbs for the CX-5 to 3500 for the CX-50. Plus, updated infotainment and some really nice quality of life upgrades like folding mirrors and a/c blowing thru the front seats.
So, time will tell how the new CX-50 holds up long term.
14 hours ago, Penatr8tor said:
Yeah, a game changer.
The AWD is not bad either. I don't want to ruin @TitusADuxass post any more than I already have but...
No worries from my side.
I've always liked the styling of the new Mazda.
I did have one once, a Mazda 323f, my first car - I bought it in a car park. Drove it 50 metres and the left outer sill (rocker) fell off. It was a really old beast though.
I liked the early 90's Mazda Styling. If I were to restore a two-seater... The 3rd gen (FD) RX7 would be high on the list. I used to love the styling of that car. The styling from 2000-2010 I didn't care for too much. The front fenders on the 2010 RX8 were ugly IMO.
Now the new styling... from 2017 on... Yeah, I like it. Especially the cutouts right above the headlights and the bumper. Looks cool IMO.
I am very much a Mazda fan. I sort of owned one: a Ford Probe GT. It's basically a reskinned slightly more performance-focused version of the MX-6. Great car and I was sad when I had to let it go (~200k miles and no more part support even from Mazda :classic_sad:). I remember a nice hot rod was the little MX-3 with the Japanese market V6 (KL-ZE) crammed in it.
I wanted a 3rd gen RX-7 in the worst way. I'd still love one if budget and space would allow.
That was a pretty cool rabbit hole to go down. I never knew about that model.
Here's a link that I think is what you're referring to. MX-3 Also interesting how anemic and slow cars were in the mid 90's. 0-60 in a blistering 8.4 seconds and here my SUV is doing 6.6 but, cars were pretty pokey back then.
Quote
PERFORMANCE
The V6 MX-3 had a top speed of approximately 212 km/h (132 mph). The MX-3 GS could accelerate from 0-60 mph (97 km/h) in 8.4 seconds, and could travel a quarter mile in 16.4 seconds. With a turning rate of 0.89 g (8.7 m/s²), its handling capabilities were one of the best in its class.
The MX-5 Miata is yet another legend that's so popular they have their own race class and overall, you just can't kill those little cars.
The new MX-5 hard top convertibles are super nice, if only they would bolt a turbo on it. I mean it's the same Skyactive G 2.5L four banger in every other Mazda... Why no Turbo?
Yup... I'm right there with ya on that one buddy. 😉👍
Miatas are great cars. A friend had one and let me autocross it a couple of times--total blast. MX-5 Cup races are nuts--especially Daytona 🤪 Here's another fun rabbit hole: Monster Miata. Classic hot rodding: take a little car (the Miata) and cram a massive, powerful engine in it (originally a Ford small block--now even an LS). My brother in law said he once got to drive one and they are scary nuts.
I briefly considered a KL-ZE swap for me Probe but the original engine never had an issue, so I really couldn't justify it (that and it was my daily driver...so nope).
Just a quick update to this printer and it's problems.
I've finally traced the strange / noisy stepper motor issue. One of the stepper looms was incorrectly wired. I really don't understand how it was running before, but it's fixed now.
I managed to let the magic smoke out of the Super 8 pro board so I splashed out on a BTT Kraken board. I've managed to get everything configured apart from the Z stepper. It homes all axes pefectly well, but when I tell it to move Z by 25mm it only moves by half the requested amount. I've to the Z config data directly from the old set up with the key data being:
rotation_distance: 4
#position_endstop: 0.0
position_max: 200
full_steps_per_rotation: 200
Here's how it looks now.
Here where the problem was.
Greetings all,
I'm at home for a couple of weeks so I thought I'd crack on with the 330.
I've fitted an Orbiter 2 extruder (I never got on with the standard one) and that area works fine.
It homes X, Y & Z correctly, quietly and smoothly.
But when I do a bed mesh calibrate it goes diagonally instead of across the bed. I also ran a speed test, it didn't like that. It clattered into the frame before I could hit the stop button - I won't be doing that again.
Anyway, I pulled the belts off and did some homing.
Something is not correct.
When I home Y both steppers Y & Y1 go clockwise, steppers X & X1 go anti-clockwise. This makes sense to me.
However homing X - steppers Y & Y1 go anti-clockwise, but so do X & X1! This does not make sense to me, surely they should be in pairs. I would have expected to see the opposite of when I home X.
Here's the stepper section of my printer.cfg
# S1
[stepper_y1]
step_pin: PC14
dir_pin: PC13
enable_pin: !PE6
rotation_distance: 40
microsteps: 128 #64 #32
#endstop_pin: PC15
[tmc5160 stepper_y1]
cs_pin: PD6
spi_software_sclk_pin: PC6
spi_software_mosi_pin: PC8
spi_software_miso_pin: PC7
##diag1_pin: PC15
interpolate: true #false
run_current: 0.800
sense_resistor: 0.022
stealthchop_threshold: 999999
# S2
[stepper_y]
step_pin: PE5
dir_pin: !PE4
enable_pin: !PE3
endstop_pin: PC15
position_endstop: 0
position_min: 0
position_max: 300
homing_speed: 50
homing_positive_dir: false
second_homing_speed: 25
[tmc5160 stepper_y]
cs_pin: PD5
##diag1_pin: PF0
run_current: 0.800
# S3
[stepper_x]
step_pin: PE2
dir_pin: PE1
enable_pin: !PE0
endstop_pin: SHT36:gpio16 #try 19 #PF1
position_endstop: 0
position_min: 0
position_max: 330
homing_speed: 50
homing_retract_dist: 5
[tmc5160 stepper_x]
cs_pin: PD4
##diag1_pin: PF1
run_current: 0.650
# S4
[stepper_x1]
step_pin: PB9
dir_pin: PB8
enable_pin: !PB7
#endstop_pin: PF2
[tmc5160 stepper_x1]
cs_pin: PD3
##diag1_pin: PF2
run_current: 0.800
# S1
[stepper_y1]
step_pin: PC14
dir_pin: PC13
enable_pin: !PE6
#endstop_pin: PC15
cs_pin: PD6
##diag1_pin: PC15
run_current: 0.800
# S2
[stepper_y]
step_pin: PE5
dir_pin: !PE4
enable_pin: !PE3
endstop_pin: PC15
position_endstop: 0
position_min: 0
position_max: 300
homing_speed: 50
[tmc5160 stepper_y]
cs_pin: PD5
##diag1_pin: PF0
run_current: 0.800
# S3
[stepper_x]
step_pin: PE2
dir_pin: PE1
enable_pin: !PE0
position_endstop: 0
position_min: 0
position_max: 330
homing_speed: 50
[tmc5160 stepper_x]
cs_pin: PD4
##diag1_pin: PF1
run_current: 0.650
# S4
[stepper_x1]
step_pin: PB9
dir_pin: PB8
enable_pin: !PB7
#endstop_pin: PF2
cs_pin: PD3
##diag1_pin: PF2
run_current: 0.800
I've checked that the motors go to the correct places on the Kraken, it homes smoothly. All four stepper motor pulleys are tight on the shafts.
Progress, but only a little.
I found that changing the Beacon scan speed down from 300 to 100 results in a good smooth beacon scan.
But, printing still has problems. It homes, it scans the bed, it does a Prime Blob and it goes wrong.
Rather than smoothly travelling to the centre of the bed to start the print, it jumps to a random place in the lower left quarter of the bed, it starts the printer and then mid-print it reports print end and stops in the lower left quarter of the bed. It does motor away from the print are  by about 10mm.
I think that there's something seriously wrong with the configuration.
