Voron 2.4 Spider 1.0 & BTT 2209 Wiring Diagram/Guide
While researching wiring diagrams for my upcoming 2.4 build I ran across an important document for those using a Fysetc Spider board in their build. The document is specific to using the Spider Board for a Voron 2.4 Build and references the Fysetc Github page for .cfg files, that can be found here... https://github.com/FYSETC/FYSETC-SPIDER
Klipper Config - https://github.com/FYSETC/FYSETC-SPIDER/tree/main/firmware/Klipper
Marlin Config - https://github.com/FYSETC/FYSETC-SPIDER/tree/main/firmware/Marlin
Voron 2.4 Spider Wiring Diagram
47399815_ScreenShot2021-06-30at10_39_34PM.thumb.png.770bd0b6e123b1a4cda03902d6228c81.png
1224440313_ScreenShot2021-06-30at10_39_52PM.thumb.png.ab323d059755a62be2f8922d6b1ea4d0.png
2044831790_ScreenShot2021-06-30at10_40_05PM.thumb.png.3dc17092b5748adccf12b093180e862f.png1242964622_ScreenShot2021-06-30at10_40_32PM.thumb.png.3abd0e7b09c312c19ae4efdf4f3598a3.png
I was unable to locate the original author, if that is you please let me know so I can give you credit!
  • 2 months later...
For me it seems that the marlin firmware is not properly configured. Number or Z steppers is set to 1 and if I set it to 4 then it complains that there is not enough drives. I was changing the pins but then I bumped into new issues.
Has anyone uploaded the firmware as is and worked fine for all Z drives?
#define NUM_Z_STEPPER_DRIVERS 1 // (1-4) Z options change based on how many
