Smol Printer Time - Salad Fork
Poisson
Welp I starting to think I did something to the motors when I I blew the original motherboard. After engaging them, they get really hot and buzz when idle. The AB motors (running at 1.1 run current) have gotten over 72C just sitting there idle after I engage them once. I clocked the Z motors (0.7 run current) getting up above 60C after being engaged, but sitting idle.
Edited by Poisson
Maybe a false alarm, I think I was over currenting the motors.
Edited by Poisson
Rear panel is attached and backpack filter wiring ran. All wiring is now finished. I still need to replace the Rainbow matchsticks I fried which should be here tomorrow.
Skirts are installed.
Klipper is a good 90% setup. It'll be time to start tuning soon! Then only only the rest of the panels will be left!
Edited by Poisson
  • Like 5
I was going to update the original post with a list of parts / mods, but that feels like history now and I'll just do that here
Main kit: Fabreeko Honey Badger: https://www.fabreeko.com/products/saladfork-160mm-kit-by-honeybadger?_pos=3&_sid=4a0e4da8f&_ss=r&variant=43029890859263
MGN9H rail for Boop: https://www.fabreeko.com/products/honeybadger-mgn9h-stainless-steel-rails?variant=43751764951295 (210mm)
Extruder: LGX Lite
Hotend: Rapido
Mainboard: Manta M8P (replaced the Manta M5P in the kit when I let out the magic smoke)
Plastic used: KVP ABS Polar White and Blue
Skirts: https://www.printables.com/model/482455-salad-fork-skirt-remix
Side mount spool holder: https://www.printables.com/model/362442-remix-for-the-salad-fork
PTFE Tube mount for Side mount spool holder (my own design!): https://www.printables.com/model/563552-ptfe-tube-mount-for-salad-fork
Back pack filter: Magenetic version from the Fabreeko github: https://github.com/Fabreeko/Salad-Fork-160/tree/main/Fabreeko_SF_CarbonFilter but with this mod: https://www.printables.com/model/567107-salad-fork-magnetic-filter-wire-channel-mod. Wire channel also from that mod.
Basket cover mod for back filter: https://www.printables.com/model/352448-salad-fork-magnetic-basket-mod-cover (you want this or carbon will get into your printer)
Screen: Waveshare 3.5" 480x800. Mount / faceplate and more details regarding connectors: https://www.printables.com/model/567213-salad-fork-35-hdmi-display-mount. Note to use this mod with the skirt remix, a small amount must be cut off as it is too long for the remix skirts.
AB Motor wire hide: https://www.printables.com/model/567201-salad-fork-ab-motor-cable-guide
Mini SB cowling (compatible with Boop Beta 4 and lgxlite):
Rapido mount for use with Mini sb and boop beta 4: https://github.com/cosmonate/VoronStuff/tree/main/Rapido_HF_Mount
Lights 2x Disco Matchstick: https://www.fabreeko.com/products/daylight-disco-stick-rgb?_pos=1&_sid=02c7fd59d&_ss=r&variant=43841072922879
Tap Kit for Boop: https://www.fabreeko.com/products/voron-tap-kit-by-honeybadger?variant=44184256479487
CAN Cable: Igus chainflex CF9-05-04 https://www.igus.com/product?artNr=CF9-05-04. I ordered 7ft to be safe, but 4 - 5 feet seemed like plenty.
Electronics fan cover: https://www.printables.com/model/341771-salad-fork-electronics-bay-fan-cover
Bed fan mounts: https://www.printables.com/model/418236-1515-bed-fan-3010-blower
Bed Wham bam 165x165mm: https://whambam3d.com/products/flexi-plate-with-pre-installed-pex-build-surface?variant=39777165344866. This is slightly oversized but wham bam is my vendor of choice for smooth PEI and it is the closest they have.
TPU Feet: https://github.com/CadmonkeyFPV/Salad_Fork/tree/master/MODS/Feet
Edited by Poisson
One little post build update:
In the end that camera USB cable I hacked together and stripped the insulation from did not work all that well (surprise). I was getting extremely low FPS and sometimes losing signal completely.
I ended up running a new cable the only way I could figure out how, down the front left extrusion and along the bottom. It's not as pretty, but's it's not terrible and I didn't have to hack a cable apart to do it:
PXL_20230903_163153010_MP.thumb.jpg.6ed7959112584cac7eca7089fd0bbabd.jpgPXL_20230903_163150440.thumb.jpg.b0121fa56509af949087a5fe9da284d3.jpg
Edited by Poisson
