- 1
nannyogg82
So I recently upgraded to the stealth burner with the Hartley 2 piece PCB. I couldn’t get my LEDs to work so did a multimeter check to see that 5v was coming from the pins. While doing this I slipped and shorted the 5v and 24v pins.
No magic smoke but the printer shut down. I initially thought I had blown the Pi but with a bit of investigation the 5v PSU wasn’t working. I wired the Pi up to the 5v pins on the Octopus board and that seemed to solve the issue. at least initially.
Whenever I print now the print cuts out after about a minute of printing. I assumed this was a problem with the power coming from the Octopus board. After checking the PSU again it seemed to be keeping up a steady voltage but I still have the same issue with the printer cutting out a minute into any print.
Is the problem likely to be with the Pi? I’ve got a new PSU arriving tomorrow so I’ll try that first. If this is a Pi issue, can I just swap the SD card with any replacement? Or will there be changes I need to make on the Pi when replacing it?
30 answers to this question
