- 0
Todd
So, I just finished building and installing Tap on my 2.4 build. Running a Phaetus Dragon HF hotend and no mods except for the Tap. Z-offset calibration was good (~.1mm) and a small test print came out great. Then I started a print with a calculated runtime of 11 hours. All went well for the first 20-minutes, but then I noticed my first layer seemed to be getting thinner and finally disappeared altogether. I immediately halted the print and raised the gantry and found the four screws securing the Dragon to the carrier had melted through the carrier and the hotend was literally dropping downward. I was printing PLA at the time and hotend temperature was stable at 210 degrees C. I believe the root cause may have been my hotend fan beginning to fail so I am replacing that.
My question here is simple, has anyone else had issues with inadequate airflow through Tap and if so was it resolved successfully?
12 answers to this question
