5
Enjoy the butter smooth filler spool holder on voron v0. Size comparable with official spool holder, but smoother and now you can quickly remove the spool holder during transport/storage without screwdriver.
Supports mounting on right front and back right. It replaces the middle panel clip, reusing the nuts. You may look at the photo for reference. Instead of original length filler, you can measure your common spool thickness and get a smaller filler remix for best space saving. Here is my favorite mini filler:
- [66mm] Filler 66mm Remix https://www.thingiverse.com/thing:5335512
- [56mm] Even SHORTER Filler Filament Spool System https://www.thingiverse.com/thing:5241172
Installed with M3x10 screws. The design will hold the nut exactly where the screw goes in. Just remember to only insert the screw after the nut has reached the bottom. It is designed to be loose to handle poorly printed filler.
