Showing results for tags 'milo v1.5'.
Milo V1.5 CNC Bench Mill Github Link Not a 3D printer but still going to be an interesting build The idea is to eventually make parts to replace the printed parts on the mill and for the Trident and V2. This is going to be a slow build, I'm self-sourcing the parts and will assemble them as parts are purchased and arrive. Years ago I purchased some parts to build a CNC machine but never completed the build. The frame and spindle were the last items to be purchased and built. Since then electronics for CNC have come a long way specifically the stepper drivers and motherboards. I already have the Nema 23 stepper motor but are larger than the suggested spec for the build. I'll be testing them with the Mellow 32bit FLY-CDY V3 Wifi Control Board when it arrives. These are the steppers I'll be testing: I have these Hiwin HGR 15 linear rails which I can cut to length, the blocks don't match the printed parts, but I can either modify the printed parts or order new blocks. The blocks alone will cost the same as purchasing a complete set of rails. The advantage of using Hiwin rails is the pre-load. Appreciate the lesson on the basic use of Fusion 360 that @Penatr8tor was kind enough to give me on Zoom. Parts ordered: Mellow Fly-CDY-V3 Complete Fastener Kit 2 x 4010 24V. Fans
- 277 replies
- 7
- selfsourced
- casaenclosure
(and 3 more)
Tagged with:
I started a new thread for anyone wanting to upgrade from Mellow CDY V3 to the BTT Scylla V1. The biggest issue with the Mellow board is the lack of memory, loading the latest Millennium OS you get a warning that you're running out of space and the lack of optoisolated circuits. The board is ordered and I'll update the process when it arrives. Here are some useful links Team Gloomy RRF BTT Scylla RRF Firmware Files For BTT Scylla
- 32 replies
- 1
- btt scylla
- milo v1.5
(and 1 more)
Tagged with:
