Showing results for tags 'barcode_labs'.
Version 1.0.0
152 downloads
SLICER SETTINGS 4 Perimeters 40% Infill DISCLAIMER You are responsible for your own actions. CREDIT WHERE CREDIT IS DUE I am unsure of the original designer of this part. If you know, let me know. BILL OF MATERIAL 7g of Filament 2 M3x10mm SHCS for attaching the mount to the sensor 2 M3x6mm SHCS for attaching the mount to the frame 2 M3 T-nut -
Version 2021.08.09
105 downloads
SLICER SETTINGS 4 Perimeters 40% Infill Supports are needed to support the panel mount DISCLAIMER Make at your own risk. Worked for me, may or may-not work for you. CREDIT WHERE CREDIT IS DUE The outer housing and lock are a modification of meteyou's gcode_buttons mod BILL OF MATERIAL Roughly 4g of filament 6 Pin MicroFit3 Molex Panel Mount Connector (Molex Part #0430200608) 6 Pin MicroFit3 Molex Receptacle (Molex Part #0430250600)
