Showing results for tags 'Maverick_'.
  • Other FDM Printers
    • Anet A8 / AM8
Found 5 results
  1. Version 2020.12.22
    50 downloads
    V0 LED Hinge This modification was designed to accomodate a Neopixel Jewel (7) in the top right hinge of the front door. A channel is present in
  2. Version 2020.12.22
    85 downloads
    V0 TopHat Mini 12864 I wanted to have the ability to use the V2 display with my V0, so designed this mod to allow for it. Although they look similar, the Mini 12864 front and back case files have been slightly altered to accomodate this design. # Config for SKR Mini E3 V2 Below are the pins that I used in Klipper for the display and a really bad representation of the wiring I performed. [display] lcd_type: uc1701 cs_pin: PB9 a0_pin: PB8 rst_pin: PB15 encoder_pins: ^PB5,^PA15 click_pin: ^!PA10 contrast: 63 spi_software_sclk_pin: PA5 spi_software_mosi_pin: PA7 spi_software_miso_pin: PA6 [neopixel fysetc_mini12864] pin: PA9 chain_count: 3 color_order_GRB: False initial_RED: 0.3 initial_GREEN: 0.3 initial_BLUE: 0.5 # Mount It! M3 threaded inserts are used in the lower wall of the back case file, this allows for M3 screws to be ran through the TopHat pieces into the case, resulting in a solid configuration. The parts are in the correct orientation for printing.
  3. Version 2020.12.22
    50 downloads
    V0 Illuminated Deck Logo A lower deck panel addition to the V0, designed to accomodate a Neopixel Ring. Print Deck_Logo_Insert_Transparent Printed with a clear filament to allow for the glow that is represented in the pictures. Recommend
  4. Version 2020.12.22
    27 downloads
    V0 LED Front Bed Mount This modification was designed to accomodate a Neopixel Jewel (7) in the face of the mount. Wiring is ran to the cable chain and ultimately to an Arduino Nano as a controller. The file
  5. Version 2020.12.22
    1 download
    V0 C14 Inlet A simple modification to the rear foot of the V0 to allow for the addition of a C14 Inlet. Note - this is not compatible with the rear, lower deck panel that sits below the Z Mount.
